Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Engine Tech / Drivetrain DIY How-To's
Reference: Recommend Vehicle Service Intervals
User Tag List
Old 06-03-2003, 12:54 AM   #1
caddy
I found Waldo
caddy's Avatar
Default Reference: Recommend Vehicle Service Intervals
As I work at an Automotive shop, i get to see many cars. We can always tell who keeps up on their maintenance. I'd thought I might post a recommended maintenance schedule that will help those wanting to know when to do what. Honda engines can take quite a beating, but ensuring that they stay reliable is dependant on their proper care. So here I will include the regular maintenance schedule that we recommend at our facility. We've been in business since 1973 and have pretty much turned it into an art here. People who follow our schedule spend less on their vehicle in the long run and avoid a lot of headaches. We benefit too because our work is more constant and our customers return. So here it goes (bear with me as most of my information is in KM and not miles)
- Transmission Fluid Flush
30,000km/20,000m for automatic, 40,000km/about 30,000m for standard (clutch fluid, prefferably Syncro Shift for hondas). When finding a shop that flushes your tranny (this applies to automatics) make sure they flush fluid through and not just drain and fill it. It leaves a lot a contaminated fluid left. Also find out if they use a varnish remover. Fluid can burn and coat the side of the tranny pan so it should be cleaned off to preserve its life.
- Brake Fluid Flush
Approx. every 730 days or sooner if contaminated
(you can use a syringe to extract a little bit of fluid and put it in a clear bottle to see if its dirty. This applies to all fluids. Also, you can buy PH strips to test it yourself, this applies to coolant as well)
- Coolant Flush
Every 730 days or sooner if contaminated or PH is off
Don't use additives in your coolant. It can cause deposits and coolant leaks and destory your water pump, kill gaskets, etc,. Use a 50/50 mix of coolant/water. If you change the coolant yourself, let the engine run a bit to let the fluid heat up and bubble to get rid of air pockets. Then you can top off the coolant and close up the system. GM claims their coolant lasts for 5 years. We've seen it turn to gel in and destroy and engine so beware.
- Thermostat
Every 5 years or sooner. If you get it done at a shop, you might want to get it done along with a coolant flush as it will cost less depending on the shop.
- Power Steering Fluid Flush
Every 60,000km/40,000m or if contaminated. Honda recommends using only genuine HONDA fluid. Using regular fluid is ok as long as you are not mixing them together. Also, if you have a high output vehicle with a more sensitive steering components, you should probably just stay with honda ATF.
-Engine Oil
Every 5000km/3000m. The more often you do it, the better. It doesn;t hurt to do it sooner if you wish. Use a well known mainstream brand (penzoil/quaker state is a good example), unless you race and know what you are using. Some exotic oils have additives (solids such as teflon) that can clog filters and cake on your crankcase. If you are using a regular oil, stick with it and try not to switch to a synthetic as it can cause a decaying effect on internal seals depending on how high your milage is. Using a synthetic BLEND is ok.
- Fuel Injection Service
Every 40,000km/30,000m
It's very hard to find a shop that does this properly. The only service i've seen that works properly and make a noticeable difference is the Enginuety services. If you are unsure, you might just try filling up at Chevron all the time and letting the Techron concentrate clean your system.
- PCV Valve
Every 15,000km/10,000m
- Fuel Filter
Every 40,000km/30,000 miles or 5 years.
- Air Filter
Replace it when it's dirty! I'd recommend a K&N filter (unless you have an aftermarket intake) because they flow better and can be cleaned.
- Spark plugs
Every 40,000km/30,000m or if you have Platinum then double that. Inspect your plug often to make sure they are not over gapped or coated with oil. There's quite a science to spark plugs that I won't get into, but just by looking at them you can tell many things about someones engine.
- Ignition, Spark Plug, High Tension (what ever name you are use to calling them) Wires
Every 98,000km/65,000m. Use a good brand such as Bosch or NGK (Maganacore, Taylor, etc). Stay away from cheap brands such as Autolite. Along with wires, replace your Distributor cap and rotor.
- Oxygen Sensor
Test your 02 sensor switching rate every 80,000km/55,000m to make sure it isnt lazy.
- Timing Belt
Every 98,000km/65,000m. CRITICAL! Don't let this one go by! If it snaps, valves hit pistons and you engine could be toast!
- Battery
Every 5 years. Have it tested often. If the battery is bad, you alternator will constantly be working to charge it and will fail. Make sure your contacts remain clean and free of corrosion.
- Shocks and Struts
Every 98,000km/65,000m Of course, this depends on your driving habits. They may last longer or shorter, but this is the recommended interval.
- Brakes
They should be inspected every oil change. If you are not totally sure how to do brakes TAKE IT TO A SHOP! It's a safety issue. Find a shop that measures the brake pads in thirty-seconds of an inch and not %. Percentages usually mean diddly squat.
- Tires
Rotate them on a regular basis based on wear. (approx 10,000km or 6,000m) Make sure your best tires are on the front wheels, where your control comes from. Replace when tread is low. Make sure there is no high spots or buldges.
- Wheel Berings
Recommended every 60,000km/40,000m, although they usually last much longer on hondas.
- Alignment
Drive on a FLAT road and make sure there is no pull to one side. I've heard some shops say there should be a little bit of pull incase you fall asleep at the wheel you don't hit oncoming traffic. This is bull, stay away from shops that tell you this. Make sure the tires aren't wearing unevenly.
- Flush Front/Rear Differential, Transfer case.
Only if you have 4x4 (CRV) or a rear wheel drive (s2000), should you worry about this every 60,000km/40,000m.
- Cabin Air Filter
Only equiped on some vehicles. Replace if dirty (you dont wanna breathe that fungus).
Other Service Items (check every oil change):
- Drive belts/Serpentine belts
Replace when belt has around 3 tiny cracks per inch, or when dry and old, or every 5 years. Make sure that the belt tensioners are doing their job.
- Inspect your exhaust for leaks or corrosion.
- Check marker and headlights, wiper blades, horn.
- Check Engine mounts, ball joints, suspension, tie rods, bushings, parking brake.
- Check for oil or fluid leaks, check to make sure coolant hoses are NOT soft and crunchy, check that clamps are on properly.
Hope this helps. If anyone has questions, feel free to ask, or let me know if it seems i've missed anything.
caddy is offline   Reply With Quote
Old 06-03-2003, 01:42 AM   #2
CiviKid
Post Whoralicious
got any how to info on flushing coolants, changing thermostats, (are performance thermostats worth it?) pvc vavles and such?
CiviKid is offline   Reply With Quote
Old 06-03-2003, 02:12 AM   #3
caddy
I found Waldo
caddy's Avatar
Default Re: Recommend Vehicle Service Intervals.
for PCV valve stuff you can check out this thread:
http://www.clubcivic.com/board/viewtopic.php?t=2049
The proper way to flush coolant is with a flush machine, otherwise you are just really draining and filling the system. If you want to drain and fill the system, disconnect the the lower rad hose when the engine is warm or if its cold, take out the thermostat or disconnect the heater hose. But I would strongly recommend getting the coolant flushed by a shop. I personally have not done it that way myself (drain and fill), i get it done with a flush machine at the shop.
As for performance thermostats, unless you are a truck doing a lot of towing or if you are doing autocross/rally i'd stick with the stock thermostat. As long as you take care of your cooling system, it should be fine. As for taking out your thermostat which some people do, that's bad. Your engine has an optimum operating tempurature. (Fluids need to reach tempurate to evaporate moisture trapped inside) On a side note, a few times on hot days, really working my engine has not moved the temp one bit. That's with the puny stock radiator too. Honda has done a good job of designing their vehicles, but of course let me point out again that you must take care you your cooling system. If you notice temps rising or loss of coolant, get it checked out right away. If you are still worried about your cooling system, i'd invest in a better radiator. After that, my knowledge is limited. So if someone has more info performance cooling, post away.
Old 06-03-2003, 03:29 PM   #4
Je
the white hatch
Thanks caddy, i didnt know you work on car's. That how u know so much s***
9 2 C i V i C VX
CCHB #7
Je is offline   Reply With Quote
Old 06-03-2003, 06:36 PM   #5
caddy
I found Waldo
caddy's Avatar
I deal with all most of the service and its my job to know what going on with everything, but I actually am not one of the techs, so I don't exactly work on the cars, i just make sure the proper work gets done. Like test driving WRX's.
Old 09-09-2003, 01:55 AM   #6
anfrey
OG スバリスト
anfrey's Avatar
i've put 50,000 miles in less than 2 years. and it seems like i missed some servicing... though everythign runs great.
set the gearshift for the high gear of your soul... you've got to run like an anfelope, out of control!
"government big enough to supply everything you need is big enough to take everything you have.
the course of history shows that as a government grows, liberty decreases." - thomas jefferson
"a wasted vote, is voting for someone that you don't believe in." - gov. gary johnson
"non impediti ratione cogitationis" - conloquium currus
anfrey is offline   Reply With Quote
Old 09-09-2003, 02:08 AM   #7
caddy
I found Waldo
caddy's Avatar
Remember that a lot is preventative maintenance. For instance, a battery that is marginal or bad, should be replaced right away because the alternator will constantly work to charge it when it just wont charge and that will burn out your alternator. Coolant flushes if not done in proper intervals can eat at gaskets, and slowly build up deposits in your radiator and engine block or take out a heater core. So just beacause you've skipped some mainenance and it's fine now, doesn't mean that it will last as long as if you did do it.
Old 09-09-2003, 02:25 AM   #8
anfrey
OG スバリスト
anfrey's Avatar
yeah, that's what i've been thinking. i'm gonna have to do a lot of flushing, checking, and replacing when i get back to my car...
Old 09-24-2003, 04:29 PM   #9
St!cky F!ngaz
Default Synthetic
My just bought my car (2001 Civic LX Coupe) and it has 21,000 miles on it. I want to change to synthetic oil, but was wondering if at this point in time it is too late to "make the switch".
St!cky F!ngaz is offline   Reply With Quote
Old 09-24-2003, 06:27 PM   #10
caddy
I found Waldo
caddy's Avatar
21,000 miles is nothin. It won't hurt anything to make the switch. I'd be concerned more if it had like 120,000 miles or something.
Old 09-30-2003, 08:56 PM   #11
Kamikaze
Sesquipedalian
Kamikaze's Avatar
great info - thanks caddy!
Got photobombers?
http://photobombers.com
Kamikaze is offline   Reply With Quote
Old 10-06-2003, 07:11 PM   #12
98hatchfreak
caddy, what kind of high qualityoil would you recommend for a stock hatch?
98hatchfreak is offline   Reply With Quote
Old 10-07-2003, 04:09 AM   #13
caddy
I found Waldo
caddy's Avatar
Regular or Synthetic?
if its regular, any of the major brands are good. penzoil/quaker state/havoline
synthetic, mobil 1, valvoline, AMS are all good brands
Old 10-07-2003, 04:12 AM   #14
anfrey
OG スバリスト
anfrey's Avatar
i picked up some amsoil when i was down in florida... damn that s*** is nice... lasts a long time, and makes my engine feel much smoother... but maybe it was all in my mind
Old 10-26-2003, 11:35 PM   #15
CivicWI97
What does a transmission fluid flush entail? Any special stuff needed?
CivicWI97 is offline   Reply With Quote
Oil Change Intervals Decipher Engine Tech / Drivetrain 6 08-22-2011 09:50 AM
Reference: Honda Service Manuals RiceGirl Engine Tech / Drivetrain DIY How-To's 19 05-29-2008 03:38 PM
Reference: Multiple Service Manual Links anfrey Engine Tech / Drivetrain DIY How-To's 12 05-26-2008 04:19 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
