Search:
Welcome to ClubCivic
O2 sensor P0141
Responding Members:
User Tag List
Old 03-16-2006, 12:25 AM   #1
dank24
dank24's Avatar
Default O2 sensor P0141
I have a have a test pipe on my car and I extended my 2nd O2 sensor so it would run properly. I sodered the wires so it was for sure a connection. But now it is throwing a code of P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2).
What could be causing this? What could be done to fix it?
dank24 is offline
Old 03-16-2006, 12:40 AM   #2
racing_4_life
hi,
did u wire them rite.i rewired my car also and extended the wires to my test pipe and at first i wired them different and then i redid it and its perfect...
what colors did u put with what.and ill check them what sensor do u have.are they still stoick and so on.
racing_4_life is offline
Old 03-16-2006, 12:44 AM   #3
dank24
dank24's Avatar
They are all extended right, I did one wire at a time. All the wires are attached to the right ones. yes, also it's the stock sensor with only 50k on it. I was thinking that since it's not a cat converter and it's a test pipe its not working? But I was hoping someone would know more then I do
dank24 is offline
'00 SI P0141 CEL, no cat, no o2 sensor *pics* youngmanvr4 Tech Archive (No Posting) 3 04-13-2008 02:02 AM
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfun??? Project "H" Tech Archive (No Posting) 18 04-11-2008 07:38 PM
wtb: o2 sensor simulator or sensor itrintegra Parts Wanted 0 09-25-2007 04:02 PM
Dual Zone Sensor or Glass Frequency Sensor? silverc1v1c Interior / Audio / Electronics 7 04-02-2004 04:53 PM
MAP sensor and TPS sensor location gabezcivic Show off your 5th Generation Honda Civic (1992-1995) 28 12-18-2003 02:47 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
