Search:
Welcome to ClubCivic
R18 motor TURBO KIT
Responding Members:
User Tag List
Old 04-13-2006, 03:54 PM   #31
io_303
NIFOC
io_303's Avatar
Originally Posted by stealthy
oh ok now i see where the cat has a flange to the "header".although this "header" wouldnt be very efficient, i guess itd be the easiest way to "just make it work"
the header is cast as part of the head, there is no other way to do it. if anything add a 45 degree bend and bam
DD: 2003 Eclipse GT
WIp: SBF 1985 RX7 on the bottle
io_303 is offline
Old 04-13-2006, 03:56 PM   #32
Sleeper
92 4doorSleeper
Sleeper's Avatar
yeah but thats why you dont bolt the turbo directly... do it like how i descride & its basicly like the average setup.
1993 Frost White Built & Boosted GT35R B18C1 Civic sedan
1992 Laguna Green BMW 325i sedan (E36/LS1 project)
1997 Forest Green Toyota Tacoma lifted on 33's
Sleeper is offline
Old 04-13-2006, 03:58 PM   #33
bizoneoeh
Ex-Gang Member
bizoneoeh's Avatar
Originally Posted by io_303
look at this image posted earlier
it shows the cat bolting on at the top, bolt the adapter plate and turbo in place of the cat and bam its the new ghetto HF mani, and since its already a gasket surface no need to make it smooth.
No s***, that's a good idea
bizoneoeh is offline
Old 04-13-2006, 04:01 PM   #34
Sleeper
92 4doorSleeper
Sleeper's Avatar
i also said that... & yeah, very true 8) with a o2 "bung" your set. I think your the only one actually reading my post.. lol
Sleeper is offline
Old 04-13-2006, 04:08 PM   #35
io_303
NIFOC
io_303's Avatar
I have noticed that it takes 2 people to say something on CC for one persont to beleave it, thats why alot of my posts include links and pics that noone looks at :)
DD: 2003 Eclipse GT
io_303 is offline
Old 04-13-2006, 04:09 PM   #36
stealthy
4 Doors For More Whores
actually, i saw the pic, just didnt notice the flange
--BJ--
- GSR Sedan
- CP 81.5 9:1 Pistons
- Eagle H Beam Rods
- Garrett T3/60-1 .63a/r
stealthy is offline
Old 04-13-2006, 04:14 PM   #37
itsmycookie
#1 asshole
itsmycookie's Avatar
Originally Posted by doug piston
werd... but i seen turbo that run off the ass end of the exhaust. so maybe somethin like that
yep that;d be the best bet
Originally Posted by aznwannabe
how would that create forced induction? I mean I can see it pulling out the exhaust faster, which would allow more air to be pushed IN. but what's gonna get the air in there?
I've seen the 350z twin turbo exhaust. they just have turbines in the muffler that pull out the exhaust faster.
but I just don't see how that would do anything forced induction wise.
it works the same way as a normal turbo the exhaust gas spools the turbo. the only difference is where this turbo is located
Originally Posted by Blahman240
You miss understood, there is a turbo kit that mounts to the exhaust pipe, not for honda's though, and it goes back to the intake.
Running just a turbo on the exhaust would cause you to loose back pressure thus giving the same effect as open header or something to that nature.
wrong. the turbo would create backpressure since it would be the most restrictive thing on the exhaust. thats why on turbo vehicles after the exhaust goes through the turbo you can run huge piping.
gotcha. I would just think that the lag would be unbearable. the car would cross the line before you spooled.. lol.
lag is from the size of the turbo. it would spool up pretty much the same as it would if it were under the hood.
also these turbo;s
- run much cooler since they;re not in the engine bay and the exhaust cools down some by the time it gets to the turbo
- draw in cooler air
- don;t need an intercooler, the piping running from the turbo back to the intake is enough.
itsmycookie is offline
Old 04-13-2006, 04:28 PM   #38
Matt.
Originally Posted by itsmycookie
wrong. the turbo would create backpressure since it would be the most restrictive thing on the exhaust. thats why on turbo vehicles after the exhaust goes through the turbo you can run huge piping. lag is from the size of the turbo. it would spool up pretty much the same as it would if it were under the hood.
You misinturprtededed or whatever way its spelt my post. I ment just running a turbo on the exhaust, not going back to the TB at all. Which will allow the turbo to spin, and nothing else to happen.
Matt. is offline
Old 04-13-2006, 04:29 PM   #39
Declectic
SeanJohn1802
Declectic's Avatar
there is a lot of researching to be done lol
Dont know if anyone has seen or heard of it, but the Honda Fit's motor is an L15 (1.5l motor) and it's design is very similar to the R18 (in terms of manifolds that is)
here is the Mugen Supercharger kit (although different, the design of the supercharger is what we with R18s would want for a turbo mani)
but right now, like said above the K20z3 is a hot item.. it's gonig to be awhile before ANYONE with a DX/LX/EX will see any engine mods... want to go fast? either should have bought the Si or swap for a K-series
I myself... 6years of warrenty on this motor.. going to leave it stock till time runs out on it, then i'll swap in a built ass motor :)
DB8 [current] EJ2 [sold] FG1 [totaled] EM1 [repo]
My Feedback
Declectic is offline
Old 04-13-2006, 05:39 PM   #40
itsmycookie
#1 asshole
well the exhaust would still have to pass through the turbo... but why the hell would you just have a turbo on the exhaust? and not hook it up?
Old 04-13-2006, 05:41 PM   #41
stealthy
it is hooked up.i believe piping back to the tb comes back around
--BJ--
- GSR Sedan
- Eagle H Beam Rods
stealthy is offline
Old 04-13-2006, 05:43 PM   #42
itsmycookie
#1 asshole
you mean on the systems with the turbo back by the rear tires? if so, yes it does come back. and the piping acts as an intercooler the it just runs to the tb like a normal setup.
Old 04-13-2006, 05:44 PM   #43
io_303
NIFOC
io_303's Avatar
The only thing that scares me about that setup is the liength of the oil and coolant lines
DD: 2003 Eclipse GT
io_303 is offline
Old 04-13-2006, 05:47 PM   #44
itsmycookie
#1 asshole
true i;m not sure on the exact setup of this i can;t remember the company that makes it
i;m sure they are setup different.
Old 04-13-2006, 06:00 PM   #45
io_303
NIFOC
io_303's Avatar
look at my past few posts, there is a link
STS is their name
DD: 2003 Eclipse GT
io_303 is offline
What Injectors Should I Use For My Turbo Kit On My Type R Motor ITR-Broom Broom Engine Tech / Drivetrain 8 06-05-2010 01:34 PM
Turbo Kit For A Stock Motor. Eric-2003EX Tech Archive (No Posting) 13 02-10-2010 08:39 PM
FS: 92 cx hatch w/ new k24a2 motor and turbo kit ExcelcivicSi Cars for Sale 118 04-04-2007 01:18 AM
R18 turbo kit under development King Bob Tech Archive (No Posting) 9 09-11-2006 10:07 PM
best turbo kit or supercharger for my B16A2 motor VTECtunning Forced Induction 9 10-25-2004 10:51 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
