Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 7th Generation Honda Civic (2001-2005)
7th Generation Honda Civic (2001-2005) 2001, 2002, 2003, 2004, 2005 honda civic coupe, sedan, hatchback si
Can you do anything to 7th gen ignitions, spark?
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 08-01-2006, 12:17 AM   #1
civydcex04
civydcex04's Avatar
civydcex04 is on a distinguished road
Default Can you do anything to 7th gen ignitions, spark?
Is there anything aftermarket or any tricks to 7th gen ignitions? Besides densos?
civydcex04 is offline   Reply With Quote
Old 08-01-2006, 09:53 AM   #2
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
02EXSILVER is on a distinguished road
There isn't much out there. I think because we use a "coil on plug" you won't find anything, aside from upgrading the spark plug. Even then you need to be carefull. One thing you may want to try, is to ground your Valve Cover where the Coil mounts to it. You can run a daisy change from the drivers side to the passangers. Then a lead from the number 4 (the one on the passanger side) cylinder, to the chassis ground at the radiator support. If you do this, it's also a good time to upgrade the ground from the trans., and the battery too. I did this, and noticed a little smoother idle. (maby it was mental but hey i like it) I used 4ga. wire, but you could use 8, 10, gague too. (I'd stay below 10ga.) I'd get a picture of mine up, but my car is still in the body shop.... maby tomorow....
Usuialy at work
I was told I could listen to the radio at reasonable volume.
02EXSILVER is offline   Reply With Quote
Old 08-01-2006, 12:14 PM   #3
Ian01ex
Ian01ex's Avatar
Ian01ex is on a distinguished road
Where is the ground on the trans? I did all the other ones but cant find this one.
Originally Posted by Beelzebubba
If I hit your knee with my shifter going to 5th or reverse, that's your damn problem. I don't care how "bad" your knees are. You shouldn't have been doing the Hustler centerfold pose in my passenger seat. Close your damn legs.
Ian01ex is offline   Reply With Quote
Old 08-01-2006, 01:33 PM   #4
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
Supposing you have a manual trans....
Follow the ground strap from the upper radiator support, to the trans.
Usuialy at work
Old 08-01-2006, 02:27 PM   #5
civydcex04
civydcex04's Avatar
I didnt think there was but thanks for that little trick
Old 08-03-2006, 01:14 AM   #6
got_sake?
1.7 ltrs of fury!!!!
got_sake?'s Avatar
got_sake? is on a distinguished road
dude that's awesome
mad stoopid props to Jezek for the sig.
Myspace
got_sake? is offline   Reply With Quote
Old 08-03-2006, 06:17 AM   #7
civydcex04
civydcex04's Avatar
do you mean take a wire from were the stock ground goes from the radiator to the thermostate, intead put it from radiator to the trans?
Old 08-03-2006, 09:00 AM   #8
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
Ok, I just got my car back from the body shop. You were right civydcex04, it is the thermostat housing. Here is some picts.
Usuialy at work
Old 08-03-2006, 01:29 PM   #9
Ian01ex
Ian01ex's Avatar
Oh if thats the one then I allready did that one I didnt daisy chain on the spark plugs yet. I need to buy some more of that black shrink wrap.
Old 08-03-2006, 04:10 PM   #10
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
I'd also suggest using that "liquid" electrical tape to seal everything up. Thats what I did after the shrink tube.
Usuialy at work
Old 08-05-2006, 12:37 PM   #11
got_sake?
got_sake?'s Avatar
that looks really good. did your gas milage improve a little?
Myspace
Old 08-07-2006, 11:22 AM   #12
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
If I fill up right... I can get over 400 miles to the tank. If I baby it, almost 500. Once, I got to 521.3, before the gas light came on.
Usuialy at work
Old 08-17-2006, 09:58 AM   #13
civydcex04
civydcex04's Avatar
So I did the daisy chain and found better feel to accelleration, and i felt the car did run smoother. Thank you. One question though, when you were speaking of replaceing the trans ground you were speaking of replaceing the battery neg to trans right? Sorry im a little slow:)
Old 08-17-2006, 10:04 AM   #14
gearbox
gearbox is on a distinguished road
lol, the engine is already grounded, and so are the plugs. that thing you did is useless. ignition solutions makes plasma coil replacements, but they break in a few months.
gearbox is offline   Reply With Quote
Old 08-17-2006, 02:19 PM   #15
Ian01ex
Ian01ex's Avatar
Gearbox you did the same thing on your car and were trying to sell grounding kits on here
Anybody got dimensions on trunk tray differences between 7th gen and 8th gen SchneidR 7th Generation Honda Civic (2001-2005) 4 06-16-2009 03:08 PM
7th gen 8th gen into 6th gen????? Project "H" 6th Generation Honda Civic (1996-2000) 10 02-29-2008 08:40 PM
Will 6th gen moonroof visor fit 7th gen? Slickone 7th Generation Honda Civic (2001-2005) 0 06-13-2007 08:25 PM
7th Gen CD/Dash Pocket (in 6th Gen?) fuzzyuu 6th Generation Honda Civic (1996-2000) 5 11-09-2006 05:26 PM
7th Gen ignition key system in 6th gen? black_radiation 6th Generation Honda Civic (1996-2000) 7 08-23-2005 01:46 AM
