Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > ClubCivic Marketplace > Site Sponsors
Site Sponsors Site Sponsor's displaying their latest hot deals and recently added products.
BLOX Products
Site Sponsors
User Tag List
Old 08-27-2006, 05:51 AM   #1
SpeedFiends
SpeedFiends's Avatar
Default BLOX Products
BLOX is dedicated to the development of high quality and affordable performance products for today's import and sport compact enthusiast. Each product is designed and manufactured using cutting-edge technologies and materials and tested using rigorous standards, offering durable products and reliable performance. Each BLOX product is designed to work with one another, giving enthusiasts the proper foundation and building blocks for developing the right performance combination.
***Limited Time Sale on Killer N/A Build Up***
Killer B-Series Combo of the Century!!!
Package includes:
HSL (High Speed Lift) Cam Shafts (Tuner or Competition)
Blox Dual Valve Springs Set
Titanium retainers
Retail at over 980!!!
PM for Special Price
Blox Performance Cam Shafts
BLOX high performance camshafts offer the enthusiast increased horsepower and torque over the entire RPM range, through various designs and custom profiles.
All camshafts start off as raw castings sourced from OEM materials. Each is then manufactured using the latest design software and chill-casting technologies. All camshafts are CNC-ground to precise and exacting tolerances and specifications.
BLOX currently offers different levels of performance through its Tuner and Competition Series. Custom (semi-blank) camshaft cores are also available for racers and engine builders that require blank cores in order to grind to their own profiles.
Below is a chart of valvetrain recommendation with each camshaft series.
Tuner Series - Uses OEM camshaft lobe designs, with BLOX profile specifications.
- Type A: Okay to use with factory valvetrain components.
- Type B: Strongly recommend using with Blox dual valve springs.
- HSL (High Speed Lift): Must use with Blox dual valve springs and Ti retainers.
- Turbo: Strongly recommend using with Blox dual valve springs and Ti retainers.
Competition Series - Cast with wider primary and secondary lobes, with Blox profile specifications
- Type C: Must use with Blox dual valve springs and Ti retainers.
B Series
BXCM-10101 BLOX Tuner Series, Type A Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10102 BLOX Tuner Series, Type B Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10103 BLOX Tuner Series, Turbo Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10104 BLOX Tuner Series, HSL Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10121 BLOX Competition Series, Type B Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10122 BLOX Competition Series, Turbo Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10123 BLOX Competition Series, HSL Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
BXCM-10124 BLOX Competition Series, Race Camshafts, B16A-B18C 1.6/1.8L DOHC VTEC
D Series
BXCM-20103 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 1
BXCM-20100 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 2
BXCM-20101 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 3
Some Specs for you guys:
Type A:
http://www.bloxracing.com/products/c...bxcm-10101.pdf
Type B:
http://www.bloxracing.com/products/c...bxcm-10102.pdf
Type HSL:
http://www.bloxracing.com/products/c...bxcm-10104.pdf
Dual Valve Spring Set
Blox Racing dual valve springs are an excellent OEM replacement. Designed to work with both OEM and aftermarket cams. Recommended for mild to moderate street motors with a maximum of 9500 rpm’s. This valve spring combination was manufactured to produce less seat pressure than most aftermarket valve springs thus reducing wear on cam lobes. We recommend that you use Blox Racing Titanium Retainers with this set up.
BXTP-10300 B-Series DOHC Dual Valve Spring Kit, B16A - B18C1/5 1.6/1.8
BXTP-20301 D-Series SOHC Dual Valve Spring Kit, D16Y/Z 1.6L
Titanium Retainer Kit
Blox Racing retainers are made out of forged Titanium providing incredible strength and a reduction in weight. When thier retainers are used with thier valve springs they feature a snap fit design which keeps the spring and retainer rotating together thus greatly reducing wear
BXPT-10400 B-Series DOHC VTEC Titanium Retainer Kit, B16A - B18C1/5 1.6/1.8
BXPT-10401 D-Series SOHC VTEC Titanium Retainer Kit, D16Y/Z 1.6L
High Compression Valves
***Pics Commin Soon***
BXPT-20200 B-Series VTEC High Compression Intake Valve Set, B16A - B18C1/5
BXPT-20201 B-Series VTEC High Compression Exhaust Valve Set, B16A - B18C1/5
BXPT-20250 D-Series VTEC Hight Compression Intake Valve Set, D16Y/Z
BXPT-20251 D-Series VTEC Hight Compression Exhaust Valve Set, D16Y/Z
Blox MAP Bypass Valve, Type A
BLOX MAP bypass valve will eliminate those troublesome check-engine lights associated with forced induction applications. It also protects your factory MAP sensor from damage occurring during high boost applications.
Fits: B16/B18/D16/Z16/F22/H22/F20C
Available in Silver, Black, Blue, Red, Gunmetal
BLOX Camber Kit
BLOX Racing front camber kit is designed to help accurately dial in your camber setting with quick adjusting sliding ball joints.
Adjustable Front Camber Kit 96-00 Civic/Del Sol
Adjustable Front Camber Kit 92-95 Civic / Del Sol; 94-01 Integra
Blox Fuel Management Unit (FMU), Type A 12:1 Ratio
The BLOX FMU is designed to increase the fuel pressure, as the pressure in the intake manifold raises. The BLOX FMU is a universally-designed product that offers a fixed 12:1 ratio.
Available in Silver, Gunmetal, Black, Gold, Blue, Red
BLOX Intake Manifolds
94-01 Integra GSR B18C
90-01 Integra RS/LS B18A/B18B
88-01 B16A/B16B, B17A, B18C5
Lower Control Arms
88-95 Honda Civic/90-01 Acura Integra
- lightweight racing rear lower control arms
- includes brand new performance bushings
- made of forged aluminum
- bolts right on without any modifications
- reduces weight by 2.5lbs
- available in silver or black
Billet Shift Knobs
- 5-Speed 10 x 1.5mm
- available in gunmetal and bronze
Reay Sway Bar Kit (22mm)
94-01 Acura Integra, 92-00 Honda Civic, 93-97 Honda DelSol
Rear Sway Bar Kit End Link Set (22mm)
Turbo Exhaust Manifold
The BLOX turbo exhaust manifold is constructed from high silicone ductile iron, using the latest casting technologies. Each cast exhaust manifold features a centralized wastegate bung between the #2 and #3 cylinders, to greatly improve the boost response, and mates to T3/T4 turbocharger. Also, the 3.5mm thick intake runners dramatically reduce the overall weight of the manifold, making the BLOX manifold superior over its competitors. BLOX turbo exhaust manifolds come with a lifetime warranty against cracks and are available for Honda B-series engines.
SpeedFiends is offline
Old 08-27-2006, 02:36 PM   #2
1992_HB
How much for a Red MAP bypass valve shipped.
93' DelSol w/ JDM D15B TURBO on 10 Psi. 191hp/165tq
R.I.P '92 HB Stolen 5/06/05
1992_HB is offline
Old 08-27-2006, 02:48 PM   #3
sohclubkid
Sick 6/6
sohclubkid's Avatar
i got a blox shiftknob (heavyweight) and i love it!
sohclubkid is offline
Old 08-27-2006, 04:54 PM   #4
tnk
tnk's Avatar
are there any reviews on the blox lca's? im thinking about picking up a pair
idiot quote of the day:
Originally Posted by aNDoNX View Post
I need a radar detector that will pick up a cop even if they aren't using a radar gun. is this possible? So like if a cop is near it starts beeping or something. I got pulled over doing 130 in a 40 and shoulda been a 5 year suspension since I'm 17 but my dad's a cop so I got out of it haha. Please anyone know?
tnk is offline
Old 08-29-2006, 12:13 PM   #5
alexsracing
how much for Adjustable Front Camber Kit 92-95 Civic / Del Sol; 94-01 Integra shipped
repping the texas valley, forum Site Admin
www.rgvimports.com
d16z6 turbo crx 12.0 @ 117.188 (SOLD)
2001 acura cl squad #10
1994 civic hb SFWD t3 in the works
alexsracing is offline
Old 08-29-2006, 12:32 PM   #6
EG-Owns you
Twin Tech Owns Your s***!
EG-Owns you's Avatar
blox is a decent brand i have there cams stage one and there intake mani but the other day i had a problem with your guys intake manifold and i dont know what i shoudl do about it so since you got a thred here ill ask you guys well i was racing ok i get into 3 gear and that metal peice on the back of the intake mani fly out the bakc of it making all the anti freeze shoot all over my engine bay and i pulled over right away after that happend lost over half my coolent it was every were i poped that pice back in place and drove it home good thing i was like 10 mins away but i mean why did it do that and how do i prevent it from happing again we pounded that peice back in thanks and you guys make some good products
[Gingerman 2007 Video]
[My Build Thread updated 4-7-08]
[My Blown Motor Pics]
N/A all day
Twin Tech Runs yo s***
I don't buy fast, i build fast
V-Tec
Nitrous is like a hot girl with an STD, you know you want to hit it but your afraid of the consequences
EG-Owns you is offline
Old 08-29-2006, 01:03 PM   #7
ryan89crx
Spoolin single cam!
ryan89crx's Avatar
where's the gauges??
www.d-series.org
www.tunewithcrome.com
Dont be so closed minded. The beaten path isnt always the best one.
Originally Posted by si-hatch86
i speak jibberish 90% of the time
ryan89crx is offline
Old 08-29-2006, 01:34 PM   #8
SpeedFiends
165 shipped
Old 08-29-2006, 01:35 PM   #9
SpeedFiends
Gauges are special order, turn around time is 2-3 days
Old 08-29-2006, 01:39 PM   #10
SpeedFiends
I'm sorry about the manifold. Sounds like a deff. manufacture defect if a fitting is comming out. But I'm not blox, I just carry their product. There's warranty for products within 60 days. Give them a call to see what they say.
Here's some info:
(510) 440-1605
http://www.bloxracing.com/resources/warranty.html
hope it helps, Jess
Old 08-29-2006, 01:47 PM   #11
EG-Owns you
thanks for the help ya ill deff call them about it cuz it worries me
N/A all day
V-Tec
Old 08-29-2006, 02:15 PM   #12
ryan89crx
Spoolin single cam!
ryan89crx's Avatar
shoot me some prices on the boost gauge and EGT gauge with probe
www.d-series.org
Old 08-30-2006, 06:14 PM   #13
SpeedFiends
all pm's replied, thanks guys
Old 08-31-2006, 10:40 PM   #14
defvayne
Set This World On Blaze!!
defvayne's Avatar
How much for turbo manifold? B-series
Discontinued 96-98 Rear Lip #0001 ][ VSM Crew #5 ][ LSMC #2 ]
defvayne is offline
Old 08-31-2006, 11:04 PM   #15
SpeedFiends
clear your PM box, lol
Thanks, Jess
Official Blox Boycott!!!! F*%$ Blox!!! Esotericimage Where and Where not to Buy from Online 9 03-21-2010 03:01 AM
blox intake and blox throttle body orioncivic Engine Tech / Drivetrain 1 09-07-2008 11:53 AM
F/s Blox stage 1 cams-type R springs and blox retainers EG-Owns you Parts for Sale 28 08-25-2008 09:31 AM
fs blox spec b cams and blox hsl cams $315 shipped each PNOYEKB18C Parts for Sale 1 11-29-2007 01:58 PM
Blox Exhaust/Blox Big_daddy2600 Tech Archive (No Posting) 4 10-10-2006 04:48 AM
HTML code is On
Copyright 2007 ClubCivic.com
Freelance Web Design
