Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Interior / Audio / Electronics
Interior / Audio / Electronics Anything Interior related Including interior electronics
Cant get my window back on the track!
Responding Members:
User Tag List
Old 09-26-2006, 09:32 PM   #1
SexualChocolate
Stan Smith
SexualChocolate's Avatar
Default Cant get my window back on the track!
So I followed the how to on how to get my window back in the track, but the window has fallen out off the track by so much, that I cant get it back on. The window is off the track halfway up the door and you cant reach it well from the speaker hole or from above so Im having a lot of trouble. Any ideas on how to get it back on?
I have a 99 Si if that matters
SexualChocolate is offline   Reply With Quote
Old 09-26-2006, 09:38 PM   #2
Shea
bored
Shea's Avatar
maybe take the whole assembly out and reset the window on the track...?
Originally Posted by CivicBoy80
sorry to rain on ur perade but 17's are considered week on the streets. and besides what only 3 inches more to say u have 20s
Shea is offline   Reply With Quote
Old 09-26-2006, 10:21 PM   #3
X-aCuTiOnA
W.W.H.D.?
X-aCuTiOnA's Avatar
http://www.clubcivic.com/board/showthread.php?t=61119
Lakers baby...WWwWwoooooooooahhhhhhhh
W.W.H.D.?
What Would Honda Do?
KA2 - Deceased
CD5 - Forfeited
EJ8 - Current - Supercharged B18C @ 10psi (236whp)
R6S - 2 Wheeled Toy
X-aCuTiOnA is offline   Reply With Quote
Old 09-26-2006, 10:41 PM   #4
SexualChocolate
Stan Smith
Originally Posted by X-aCuTiOnA
Thats the how to I was referring to when I said I followed the how to on this site. BUT it simply says:
"With the front track loose and the window down, you can now move the bottom of the window back in track by fitting it into the rubber seal in the metal track."
But Im unable to get more than half of the window back in the track, no matter how hard I try. My window has done this before, and I followed the same how-to but it seems to be in way worse condition this time. Maybe I should break down and take it to the dealer.
Old 09-26-2006, 11:27 PM   #5
aaren99
aaren99's Avatar
so you cant roll your window down all the way? if its stuck halfway up you can loosen the bolt behind the speaker and try and move the guide more over to the front of the car. Then you can plug your power window switch back into the clip and roll the window down then you can put the guide back onto the window and tighten the bolt. hope that helps but really couldnt understand your problem very well..
aaren99 is offline   Reply With Quote
Old 09-26-2006, 11:37 PM   #6
SexualChocolate
Stan Smith
Thanks for the response. Sorry if Im not articulating this very well. The window will roll all the way down, and about 1/2 way up (typical symptoms of the window falling out of the track). However, half of the window seems to be in the track, and the other half is partly of of the track. Not to mention the back part of the window seems to be misaligned as well. But I cant seem to get up in there in the door to put it back on track. The bolt is completely loosened and off.
With the bolt completely off, should I be able to pull the track completely off the window and then realign it to put the window back in? Maybe I'm just being gentle, but Im a little hesitant to yank at it.
Old 09-26-2006, 11:43 PM   #7
NOFX
I'm NOT eran!
NOFX's Avatar
Sounds like you hav damaged parts on your car. I wold recommend doing what you shoudl have done last time you set it back on the track.
1 - Once it's on the tracks, don't move it until it's actually fixed.
2 - Get the scissors replaced.
3 - Make sure the tracks are kept properly lubed.
NOT ACTIVE ON SITE. STOP ASKING ME WHERE I BUY MY PARTS.
[OEM 98 Discontinued Rear Lip #0009]
[OEM 98 Discontinued Front Lip #0001]
NOFX is offline   Reply With Quote
Old 09-28-2006, 11:05 PM   #8
brentl21
brentl21's Avatar
ya i have ran into the same poblem but the rubber in the track has started to like tear and so when the window is all the way down it catches on it and sometimes it makes the glass jump out of the track......so i don't know what else to do any advice?
i will be easier to take the whole door panel off because you have more room to guide the glass back into the rubber track
brentl21 is offline   Reply With Quote
Old 09-28-2006, 11:12 PM   #9
99EBPSi
RIP - MH - 11/06/06
99EBPSi's Avatar
I took mine to a honda dealership/service
35 bucks and a warranty. Might I suggest finding a Honda Service center?
99EBPSi is offline   Reply With Quote
driver window off track zoomoutt Tech Archive (No Posting) 7 05-17-2009 03:51 AM
window off track? help!! Coutts Tech Archive (No Posting) 7 07-03-2007 07:32 PM
window fell off track...help me out. NFR_AP2 Tech Archive (No Posting) 29 01-11-2007 07:54 PM
power window off track dbisknot2ez24ge Tech Archive (No Posting) 6 02-20-2006 01:01 PM
Window off track, help! Kakusandan Tech Archive (No Posting) 3 09-24-2004 12:51 PM
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.3 (Lite) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 2007 ClubCivic.com
Freelance Web Design
