New coilovers now car is bouncy, help!
tyrexus
I got the height adjustable coilovers installed with new lower control arms (aftermatket) and sway bar 24mm. Now my car bounces too much on every bump. Someone suggested getting a low profile set of tires on new rims. Google is very vague on the topic. Help?!
Sent from my LG-D852 using Tapatalk
pmac193
Thundermuff
Before tightening the front and rear lower controls arm bolts, did you jack up each corner to ride height to set the preload? Alternatively you can wait until the car is on the ground to tighten all bolts running through a bushing. Lower profile tires will not affect the ride comfort in a good way.
tyrexus
I understand that lower profile tire will make you feel every bump on the road. My real problem is that I get launched off my seat. The coilovers and rear lower control arms and sway bar were installed by a shop that specializes in aftermaket parts for older generation civics, acuras etc. I assumed the new what they were doing.
tyrexus
They are all about sports tuning.
pmac193
Thundermuff
Specifically what parts were installed and were you going from stock springs to coilovers?
Please specify the brand and model of equipment used. No amount of adjustment could make no-name or cheap quality products ride well.
I guess you didnt realize that Blox makes "racing" designed coilovers only, meaning the ride is suppose to be very stiff. Thats a counterproductive choice for a daily driver. If you can return the Blox's then you should and call the extra fees a loss for long term comfort and quality gains if you select a better suiting coilover set.
Oh, and google is NOT vague if you research well enough because I can guarantee I'll find clear answers within 5 minutes of dedicated research. I dont mean to be rude, but quite honestly you clearly didnt thoroughly research your purchase choice.
tyrexus
Your sure know how make people like s**t though. End of thread. Thanks for all your input either way.
R3dline
you aint gata lie to kick it, did you buy sleeves from ebay and put em on your busted ass stock shocks?
How did I make you a fecalpheliac?
I couldve easily chastised you like a jerk, but it was constructively said. Its a learning lesson. Be mature, admit you made a mistake then move on. Its that simple. Otherwise, youre more likely to repeat similar mistakes.
tyrexus
dancam
Member
Does it launch you off your seat because its as stiff as a board when you hit bumps or because the suspension travels really far and then throws the back end up?
tyrexus
I tried pushing the rear corner of the car and I saw more movement from the tires flexing than the actual suspension; stiff as a board I guess.
Well, suspension does take up to a few weeks to settle in a soften a little, but it likely wont soften up much if its as stiff as you describe. If returning them isnt an option for you then you'll need to learn to accept having a rough ride. Maybe put a feeler out locally to swap them for something more to your liking.
dancam
Member
Oh? What size tires do you have? (Not just the rim size but the tire) and what pressure are your tires at?
tyrexus
195/55/15 29 PSI front, 28 back. I lowered then from 32 and there was a bit of improvement. Don't want to put them lower than that.
