Oil change place overfilled my engine - Will it cause damage?
Diana Nam
How would a dipstick even break?
not likely its made of metal thats about 1/16" thick or a little thinner, only time i seen them break is it was bent back and forth to many times on one spot
98civex
It's raining here and turning to snow tonight. Don't have a garage so at this point I'll have to drive it like that and hope nothing happens
Diana Nam
damn that sucks. you might as well just take it easy with the car for the time being
98civex
Does the dipstick look crooked to anyone? At least crooked enough to show a quart over?
Diana Nam
it wouldn't matter the top of the stick stops it and it will only go down to certain height in the oil
98civex
So then my dipstick isn't broken as that oil tech suggested? Lol
AllStockHatch
Unregistered User
I've overfilled once. I used medical tubing to put down the dip stick tube and used a large syringe to extract the extra oil.
98civex
I actually just tried that and wasn't able to extract too much. It lowered the level about 1/4" from what I posted
98civex
If damage were to happen, wouldn't it have already since I've driven it?
dancam
Member
Re-read what people said would happen in answer to your first question. None of that causes immediately catastrophic damage. Damage? Most likely, but not that your engine instantly quits. When the guy showed you where your dipstick was broken how would that affect how it measured?
98civex
How would I know if any damage has occurred? This is bad timing for me. We are getting hit with another 8+ snow storm and I don't have a garage and I need to drive my car.
I do a lot of highway driving, won't the oil just burn off eventually and go to proper level? I believe my car has always burned about 1/2 quart every 1000 miles
dancam
Member
You could tear the engine apart and look... Otherwise you wont be able to tell. If you burn off 1/2qt per 1000 miles then itl be overfull for 2000 miles if it stays the same. Cars tend to burn it faster when their overfull though. But i dunno, i got a small 2 1/2 ton floor jack with stands for $25 a while back so i have no problem crawling under my car in the dirt or snow. Even with a sizzor jack and stands its not that bad to crawl under... But its up to you if you wanna do it. Other guys had tips, when you tried the syringe did you do it with cold oil or right after driving with hot oil? Hot oil would go way faster.
98civex
It was cold and not driven for couple days. I wasn't sure if I tried with warm engine if the plastic tubing would melt
lo-n-slo
I don't understand what is the big deal. Get under the car, unscrew the plug so that some oil drains out into a pan and recheck the oil level, then wipe the mess up.
98civex
It's due to bad timing. We keep getting hit with snow here in New England and I don't have a garage
