endo617's 98 Civic LX Project: Balance
endo617
Few more parts came in, going to be a crazy spring adding all these mods.
endo617
Prothane front sway bar bushings and endlinks, installing my front bar back on.
Low Temp TStat
H22 290cc Injectors
I was looking for a good set of CTR/ITR +99 Spec Cams but no luck. Stage 1 S2 was the mildest cam I could find.
endo617
91 Civic Si:
The way the turbo is set up I need studs to bolt it up
Volvo turbo comes with m8 bolts and studs, had to bore out to fit through M10 studs.
This needs to be shaved to fit a nut.
endo617
Buddy gave me his subframe because he went RHD. No more snapped screws, so I can put my front bar back on.
Also gave me a complete Eibach sway bar kit
T Fittings weren't actually 1" like they said. Had to improvise.
endo617
No more chasing wiring, picked up a complete dash harness and EX engine harness.
endo617
Progress was made today
Intercooler needs two 90 elbows to be bolted up official
Ordered a new BOV pipe, this one is 2" need 2.5"
endo617
battery location was too tight, Deka etx14 came in, I'm making a tray for it. This is NOT where it's going to be when I'm done.
I'll be using the M8 holes in between the battery to bolt the tray I'm making.
Went to Race Depot (Home Depot). This is my tray making material
endo617
Here's the after on the LCA's, half ass polish
Catback came in for the EF. New radiator is in there too with slim fan and shroud, forgot to take a pic.
endo617
Making brake ducts, using these cheap EG ones and making them fit.
Need to trim the left corners a bit to make it look better.
