Power/manual door question
SoLo98
i have a 98 civic coupe and i needed a drivers side door, the car i have came with power windows and everything but the door i got is a manual door, i was just wondering if it would be a simple task to just swap everything or am i stuck with the manual components cause i notice that since i switched doors that my passenger side window no longer works either.
Yes, you can remove all the current manual window components and swap in the powered components.
mc360
boosted hx
All you should have to do is swap the window regulators, manual and power should bolt up the same hopefully. You will also have to swap the door harnesses around since the manual door will have less pins/wires in the harness. Oh and your passenger door gets power from the driver side master switch is why it doesn't work now.
