White smoke, options: 91 Civic Hatch
Aldo
Just bought my first car, it being a 91 civic hatch I wanna swap it as it leaves a trail of white smoke behind so I thought if ima change the gasket might as well swap if I can, Any help on what I should do first and how I should go about this? Again first car any help is good help.
Mr.Baker
Mr. Search
Budget, time and power goals?
That will dictate where this goes.
Aldo
Budget is mainly gonna be going toward a what I should do first, time if say I have all the time in the world Other than work days kinda wanted to make this a small hobby, as for power I Don't Need it all right away but I would like to end at 300 hp at least
I think you missed the point of Mr.Bakers questions. State your approximate budget. It better be big because that's the only way you could reach 300hp with a '91 Civic. Doing so on a D-series engine would entail a finely tuned turbo build with quality equipment and several internal upgrades. Otherwise, you would have to upgrade to a much beefier engine, such as a K20/24 or H22, which would still require some added upgrades. Either direction will cost you several thousand dollars and a lot of build time, meaning your Civic will not be driveable for a while.
Mr.Baker
Mr. Search
Budget is mainly gonna be going toward a what I should do first, I would like to end at 300 hp at least
You're working backwards, so good luck with that.
A reliable 300hp build, which more than likely will include boost, is not cheap, which is why you need to be realistic with what you can afford to do. Hence why I said budget will dictate where you go with this.
This. I 100% agree.
