First off I am a new owner of a '00 SI and I love it. I picked it up last Tuesday. I love the car but there is a few things that need fixed.
Everything done to the car was that way when I bought it. I have not done any mods myself yet.
There is a really really small exhaust leak where the header meets the cat, or in this case test pipe. The top past of the flange on the test pipe is where the leak it. I've tried working of it but I cant get it to seal...yet.
The more annoying problem is the CEL I am throwing. Its a P0141 CEL. Which is O2 Sensor Heater Circuit Malfunction (bank 1 sensor 2).
I did a couple hours of research but everything I found helped me with this.
I got under the car again today to try and fix the leak (failed) and look at the sensor when I noticed something. *Refer to pics*
I only have one O2 sensor it seems. Its right before the cat/test pipe. Like 4 inches. I thought the first sensor was toward the head/block before it makes the bend to go under the car.
So since I only have sensor 1 I was surprised I was throwing a P0141 heater Mal instead of something like a P0140 which would indicate that the sensor is bad or the cat is bad, or no sensor at all.
The exhaust system is a header that looks like a T1R header, T1R test pipe and Apex'i WS2 cat-back.
*Edit* Something else I had noticed is it feels a little sluggish. I dont know if throwing this code could cause this.
O2 sensor in header - header right test pipe left
Down the T1R test pipe
T1R test pipe and at the top left you can see a plug, my guess is this is the sensor 2 O2 plug?
T1R header
T1R header
