I was wondering if anyone knows what 2 do 2 make 03 cobra rep wheels fit on a 2010 civic si sedan I've seen it done but jw what all do I need for the set cause the bolt pattern is the same
What's the question exactly? You say the bolt pattern is the same and still want to know how to bolt them up? Or are you asking for the tire size? Going to need more information and clarity here.
You'll probably have better luck going on 8thcivic with this question. There aren't many 8th gen guys here. I guess you should try to find out the hub size. ours is 64.1 i believe so you may have to get some hub rings, which I always advise when getting rims with a different hub size as the oem size anyway.
