GhettoSmurf
Hi all,
I've just bought an '04 EP2 1.6 VTEC for not a lot of money.
As expected, there's a few bits an pieces to do on it but thankfully between this forum and a few others I've managed to sort most of the more noticeable issues but I'm still having problems with the below.
Originally the speedo was completely dark whereas the tachometer and fuel/temp gauges were fine.
I moved some of the bulbs around and now have it in such a way that I can see everything in the dark (but its still not perfect)
It seems like the working bulbs will not work in some positions however. I'm thinking I may need to gently sand the contacts or something like that?
The dashboard left indicator/turn signal light and the full beam light are also no working (the turn signal and full beams do actually work though!)
Are these the same as the instrument lights to fix or do I need to crack open the casing to get at them?
Again not the biggest issues, the car drives great and am very happy with it!
Thanks,
G
Thanks,
G
