$10 Off All Competition Clutch Products plus Free Ground Shipping
Use Coupon Code 10OFFCOMP
Competition Clutch Stage 1 - Gravity Series 2400 Clutch Kit
The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel. 300 mile break-in recommended with this set-up.
DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool.
Starting at $255.50 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-1-gravity-series-2400-clutch-kit_246.html
Competition Clutch Stage 2 - Street Series 2100 Clutch Kit
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Starting at $305.00 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-2-street-series-2100-clutch-kit_247.html
Competition Clutch Stage 3 - IronMan Street/Strip Series 1680 Clutch Kit
This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool.
Starting at $435.50 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-3-ironman-street-strip-series-1680-clutch-kit_249.html
Competition Clutch Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Starting at $395.00 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-3-street-strip-series-2300-clutch-kit_248.html
Competition Clutch Stage 4 - Strip Series 0620 Clutch Kit
This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 0620 Series kit includes a performance pressure plate, a six puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Starting at $345.50 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-4-strip-series-0620-clutch-kit_251.html
Competition Clutch Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-4-strip-series-1620-clutch-kit_250.html
Competition Clutch Stage 5 - Strip Series 0420 Clutch Kit
This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 0420 Series kit includes a performance pressure plate, a four puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-5-strip-series-0420-clutch-kit_253.html
Competition Clutch Stage 5 - Strip Series 1420 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
http://www.tunersports.com/products/competition-clutch/competition-clutch-stage-5-strip-series-1420-clutch-kit_252.html
Competition Clutch Lightweight Steel Flywheel - ST
The ST flywheel is recommended for naturally aspiriated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Lightweight Steel Flywheel:
•Preserves low end torque and drive ability
•One piece ring gear for high durability
•Weight varies from 11 lbs. to 14 lbs. depending on application
•Well suited for Stage 1 and Stage 2 clutch kit applications
•Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
•CNC machined and balanced to O.E. specifications
•Reduced Mass = Increased Accleration
•Meets and exceeds SFI 1.5
Starting at $178.10 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-lightweight-steel-flywheel-st_254.html
Competition Clutch Ultra Lightweight Steel Flywheel - STU
The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Ultra Lightweight Steel Flywheel:
•Weight varies from 8 lbs. to 10 lbs. depending on application
•Well suited for Stage 3 and up clutch kit applications
Starting at $196.10 Shipped
http://www.tunersports.com/products/competition-clutch/competition-clutch-ultra-lightweight-steel-flywheel-stu_255.html
