killroo
Hello, I have a 1986 Honda Civic SI that is fuel injected. my issue started when my car whould not start one morning, found out i did not have spark changed the pick-up coil in the dist. good as new drove fine until the motor warmed up to temp and it stalled wile at idle, started back up just fine and stalled again , sometimes it starts up right away othertimes it takes a bit of time. car drives ok unless i let it idel
now the car stalls under cold start and when warmed up
i have checked the following:
timming
crank angle sensor
temp sensor
tps
map sensor
fuel pressure
main relay
when i checked the TPS sensor the Ohms would jump around as i opend and closed the throttle not sure if this means its bad or not?
timming
crank angle sensor
temp sensor
tps
map sensor
fuel pressure
main relay
