No codes, I cracked the banjo on the injection pump and no fuel pressure when this happens,I also shot a little ether and it fired right away,it's definitely a fuel problem, which is cured each time I remove and replace the solenoid/alternator fuse.I sanded the fuse and put some dilectric grease on it, fuse seems tight and making contact but it still randomly won't start when cold unless I remove and replace the fuse, then it starts righ up.
