97EKHatchback
Symptoms
The ride height is off on one wheel or the fender is drooping. The steering wheel favors left when driving straight.
Here is the before and after alignment specifications. I would like to install coil overs but I want to fix my current right front camber issue and steering wheel being off.
Before Measurements
Left front 0.0° Camber
Left front 1.1° Caster
Left front Toe -0.05° (Out of specification)
Left rear -1.1° Camber
Left rear 0.22° Toe (Out of specification)
Right front -1.5° Camber (Out of specification)
Right front 1.2° Caster
Right front 0.40° Toe (Out of specification)
Right rear -1.9° Camber
Right rear toe 0.05° Toe
Total Toe front 0.35° (Out of specification)
Front steer ahead -0.23° (Out of specification)
Right rear 0.05° Toe
Rear total toe 0.27°
Thrust angle 0.09°
Current Measurements
Left front -0.1° Camber
Left front Toe -0.02°
Left rear -1.3° Camber
Left rear 0.06° Toe
Right front -1.3° Camber (Out of specification)
Right front -0.02° Toe
Total Toe front-0.04 °
Front steer ahead 0.00°
Right rear -1.8° Camber
Right rear toe 0.10° Toe
Rear total toe 0.16°
Thrust angle -0.02°
The only way I have thought about fixing this is installing adjustable control arms on the front (to fix camber) and rotating the steering wheel a few degrees right (fix off centered steering wheel).
Any help would be appreciated.
Before Measurements
Thrust angle 0.09°
Left rear 0.06° Toe
Thrust angle -0.02°
