2000 civic si cooling fan question
Civic fans don't run very often under normal conditions.
it used to turn on when left idling for 20 minutes
I would imagine that the fan would not run often in the Oregon climate, particularly if you live near the coast.
If you unplug the fan switch connector and short it with a jumper wire, does the fan run?
Have you tried bleeding the cooling system? Have you tested the switch?
Unplug the 2P connector and short the two terminals of the wire harness connector with a paper clip or wire.
dylanmt20
ok i checked the fuses they all looked good but i switched them around anyway and still have no fan
Wire power and ground from the battery directly to the fan 2P connector to see whether it runs.
