DeadCivicJen
Hi everyone! I could use a little help here....I knew my head gasket was failing. Car overheated (bad coolant temp sending unit wires too short so I didn't have temp gage) long story short the car died and wouldn't start. Starter is fine, belts turn. It seems like the engine isn't turning hard enough. Getting air, fuel, and spark. I am going to grab the cylinder compression test kit later. I already replaced the head gasket and it still won't start. I am thinking the piston rings are fried. Im extremely limited on cash right now so I need this to be as cheap as possible. If I test the compression and find it low I would imagine its the piston rings. Can I replace them without pulling the entire engine out? Can I get away without having the cylinders bored? Do I need any special tools? Anything else I can try? Please help! I need my car back.
