Fresh101
Hello everyone, I am new to this forum but not new to the scene of imports. I am currently seeking for some help with a issue in my car with my passenger power window. I have searched the forum and notice other member's having similar problem but in a different year model civic and the wiring diagram that they used to test the switch (driver and passenger), make me believe they are different not letting me test any further to correct the problem.
I have been working on my car for the past 2 weeks, getting everything in order. My passenger windows was not working since day one from purchasing it. Yesterday, I went and replace regulator/motor assembly and hit the switch and it just went up all the way and couldn't get it down. I tried using the master switch (driver side) with no luck, it doesn't respond at all. I thought that maybe the switch was broken or something, so I went and replaced both switches (master driver side and passenger) thinking that it will get it to work but with no success. I tested the switches in my best friend car and they work fine without any issue, I also used his switches and it still doesn't work. I tested the regulator directly with battery and it works fine up and down. Tested a few other things and notice that when I press down on the switch (passenger) the negative/ground signal does not pass to pin 2 to make the windows go down. Then I manually did it myself by bridging pin 2 (one of the lead to the motor) and pin 3 (ground) and it went down when I pressed down. And then again, when I press up, it goes up normal and the pins that become bridged on its own when pressing up, is pin 3 (ground) and pin 4 (other lead to motor). Can someone please help on how to resolve this issue? Thanks in advance
