cj898854
New timing belt and water pump
New thermostat
New fuel rail and injectors
New coil packs
New plugs
New crank positioning sensor
New radiator
New head gasket
And much more 220k on it
All was replaced in the past year and starting last week it just wouldn't start. I got it to start up today to get it home and now it won't start again. I'm thinking ecu issues but I don't know how to check it or if I'm able to replace it myself. I've got relays inside the dash that click when I first turn the key and it cranks and fires a little but won't stay running. It's radiator fans wouldn't turn on and it started over heating again. Has anyone had problems like this? I've also checked the fuel pump and relays I've got fuel and spark and the timing is spot on like it should be. The car starts only when it wants to but overheats when it does run.
New thermostat
New coil packs
New plugs
New radiator
New head gasket
