Buckeye
A question for the masses.........I have a 2002 Honda Civic (Standard transmission with 175,000 miles). I have encountered fault codes P1361 & P1362 on 3 different occasions (over a span of about 4 months) where I was driving and my car "jerked/hesitated" slightly and went into "limp mode". On each occasion I was able to drive home and after setting for about an hour the car re-starts and runs fine. I read several different forums and decided to replace my "camshaft position sensor" over the weekend. When I completed this work (it took me about 1 hr) my car would not start as it was "immobilized" - it did not recognize my programmed key. I obtained the "brake" code for my Civic as I had used it about a year ago due to losing my keys and the car would still not start. This left me very confused as I was concerned that maybe something was wrong with my ECM. Because I was paranoid I put the original camshaft position sensor in the Civic and still no luck in starting (even though I realize the sensor should have nothing to do with the immoblizing system). I had it towed to a Honda dealer and they programmed the key(s). My question is what can cause the ECM to lose the programmed keys? I asked the dealer if there was the potential for the ECM to get a hard short that clears its memory........has anyone experienced something like this?
