just want to know if anyone knows a site that gives good instructions on removing original tail lights and installing some after markets ones......
I would like to see the pics cause it would help give me a visual of what i got to do.eharkins said:you HAVE to take off the bumper to remove your lights. there is one screw from the bottom that you can't get to unless you remove the bumper. i have some pictures on here somewhere if you need them just let me know.
I did the tail light switch today. and yes there is a bracket that is under the lights that hold the stock light in......but u dont have to take off the bumber to get at the screw u need to take off. All you do is go under the car and directly beneath the light and unscrew the middle screw of the black bracket. Then lift the light up and push down on the two clips that you can see between the light and the bodyeharkins said:you HAVE to take off the bumper to remove your lights. there is one screw from the bottom that you can't get to unless you remove the bumper. i have some pictures on here somewhere if you need them just let me know.
