Hey All,
I'm in the process of purchasing a 2005 Civic SI-G, and while the car in general is great, there have been some issues. The biggest has been a faulty alternator. I took the car to a Honda dealer for a comprehensive car inspection and they told me that the alternator had to be replaced as:
Alternator output @ no load = 14.37V (good)
Alternator output @ load (lights, AC, defroster on) = 12.54V (bad)
I took the car back to the used car dealer to get the alternator replaced, and they claimed to had replaced it. I then took it back to the same Honda dealer to get re-inspected, and they reported:
Alternator output @ no load = 14.34V (good)
Alternator output @ load (lights, AC, defroster on) = 12.50V (bad)
Just to be on the safe side, I took it also to a Honda performance shop, and they confirmed the low output... they mentioned that the alternator should produce an output of 13.0-13.2V, when under load. As a side note, all other electrical checks (battery, crank test, diode ripple) were normal.
What should the alternator voltage output be with and without load? Is this alternator bad? Should I hold off on the purchase until an alternator that produces an output of >13.2V be put in, or is that unrealistic?
Thanks!
Thanks!
