2009 Civic sedan: new compressor constantly running
Jayk S
Hello all, I have an 09 civic sedan that i recently replaced the compressor on (as well as the high pressure hose, low pressure switch, and receiver/dryer.) Im am now having an issue with the compressor not shutting off at all, (no cycling, won't shut off via the switch) which i believe is causing the evaporator to freeze up and block the airflow to the vents, (assuming thats whats causing it) and completely destroys my gas mileage in the process. Has anyone had any experience with this problem? if so, were you able to fix it?
