90-91 si civic cluster pinout circuit diagram
LanceVigil
i would really appreciate it if anyone could give me a link to the cluster pinout circuit diagram that shows what color goes to which component.
James315
What exactly are you trying to do? If you simply trying to put a 90-91 cluster into a 90-91 whatever trim level civic or crx its plug and play now if you have a 88-89 cluster its not so simple actually i believe the 88-89 cluster is actually a little smaller than the 90-91 cluster. but anyways more info needed and i can provide more help then.
LanceVigil
I'm trying to put a 95 integra gsr cluster into a 90-91 civic and i need the wiring diagram for the 90-91 civic so i know which color wire is which component
mhorton
I don't have exactly what you want, but maybe this will get you started. This is what I used to hook up an SiR ef cluster, so just look at the right side. unfortunately it lists in order of the SiR, and does not list the colors, just the pins. That is what I prefer since color could be off, but pin numbers will always be right.
