91 Civic LX air conditioner
Discussion in '4th Generation Honda Civic (1988-1991)' started by 91LXDriver, Oct 15, 2017.
  1. 91LXDriver
    91LXDriver New Member
    Oct 15, 2017
    35
    93223
    91 Civic LX, the ac works but cycles on and off every 5 to 15 seconds. Has automatic transmission, if this helps.... it has a 4 year old r134a system in it....
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,223
    United States
    When the A/C cycles on, the air blow cold and does the condenser fan run?
  3. 91LXDriver
    Oct 15, 2017
    35
    93223
    A.c. gets cold and all cooling fans run but just for the 5 to 15 seconds the a.c. pump runs
  4. 91LXDriver
    Oct 15, 2017
    35
    93223
    No weird sounds or smells, there are what appear to be bubbles in the sight glass window
  5. boofoo
    Oct 15, 2016
    2,223
    United States
    There's only one A/C fan next to the radiator fan. Does it run?
    Inspect the front of the condenser. Are fins clogged with bugs and road debris?
  6. 91LXDriver
    Oct 15, 2017
    35
    93223
    Condenser is clean and the fan by a.c. runs when compressor is engaged
  7. boofoo
    Oct 15, 2016
    2,223
    United States
    While engine is idling with the A/C, spray cold water on the front of condenser with a garden hose. Does the A/C stay on much longer by cooling the condenser?
    Did you do the R134A conversion?
  8. 91LXDriver
    Oct 15, 2017
    35
    93223
    Conversion was done by previous owner at a shop.
  9. 91LXDriver
    Oct 15, 2017
    35
    93223
    Ill try the water test after the cruise control matter is done
  10. boofoo
    Oct 15, 2016
    2,223
    United States
    How long ago?
  11. 91LXDriver
    Oct 15, 2017
    35
    93223
    Approximately 4-5 years ago
  12. boofoo
    Oct 15, 2016
    2,223
    United States
    How long have you owned the car?
    Has the A/C ever worked properly since you purchased it?
  13. 91LXDriver
    Oct 15, 2017
    35
    93223
    I've had car for 3 years and a.c. has always worked this way
  14. boofoo
    Oct 15, 2016
    2,223
    United States
    So the A/C has never worked properly while you have owned the car?
  15. 91LXDriver
    Oct 15, 2017
    35
    93223
    Correct
  16. boofoo
    Oct 15, 2016
    2,223
    United States
    Do the test I suggested with the water hose.
    If the A/C still short cycles, the A/C system may be overcharged with refrigerant. You'll need a manifold gauge set to test this possibility.
  17. 91LXDriver
    Oct 15, 2017
    35
    93223
    Water test completed, it still cycles like mentioned prior. I'll take it to a shop for further....
    Thank you for the assistance on both matters
  18. boofoo
    Oct 15, 2016
    2,223
    United States
    :thumbup:
Loading...
Share This Page
