91 Civic LX cruise control
Discussion in '4th Generation Honda Civic (1988-1991)' started by 91LXDriver, Oct 15, 2017.
  1. 91LXDriver
    91LXDriver New Member
    Oct 15, 2017
    44
    93223
    I have a 91 LX, the cruise control works sporadically at best. I replaced the brake pedal switch 6 months ago. The CC dash switch lights up but when cc button is pushed its a crap shoot whether it will work..
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,243
    United States
    Auto or manual transmission?
  3. 91LXDriver
    Oct 15, 2017
    44
    93223
    Automatic
  4. boofoo
    Oct 15, 2016
    2,243
    United States
    Check the shift position console switch.
    Is CEL code 17 thrown?
  5. 91LXDriver
    Oct 15, 2017
    44
    93223
    What and where is this and why???? No 17, but a constant 16..
  6. boofoo
    Oct 15, 2016
    2,243
    United States
    The gear shifter has a position switch in the console.
    Here's the why:
  7. boofoo
    Oct 15, 2016
    2,243
    United States
    Reset the ECU by removing the Hazard fuse for 5 minutes. Does code 16 return after driving? Does code 17 show up?
  8. 91LXDriver
    Oct 15, 2017
    44
    93223
    16 is a reoccurring code. 17 has not showed itself.
  9. 91LXDriver
    Oct 15, 2017
    44
    93223
    So is this saying to replace the switch or is this just a rest of the switch?
  10. 91LXDriver
    Oct 15, 2017
    44
    93223
    Removed the neutral switch, cleaned contacts, reset ECU, drove it still no luck, and code 16 showed again which according to my service book is a fuel injector issue which is a whole another matter..
  11. boofoo
    Oct 15, 2016
    2,243
    United States
    Is the car having any driveability issues? Code 16 generally causes no-start issues.
    The position switch must be tested with a multimeter. If you have one, you should be able to pinpoint the CC problem with a few different tests.
  12. 91LXDriver
    Oct 15, 2017
    44
    93223
    Only start issue it had was when hot and left sitting for 10 minutes or so it would just crank with no start. After searching I found it was possibly a bad temp sensor, replaced it and no more hot start issues.
    I have a multi meter but not sure what I'm looking for or at....
  13. boofoo
    Oct 15, 2016
    2,243
    United States
    A no-start issue in combination with code 16 tells you to resolder the main relay or replace it.
    Are you willing to do some electrical tests with the multimeter if I guide you?
  14. 91LXDriver
    Oct 15, 2017
    44
    93223
    Do I need to remove switch
  15. 91LXDriver
    Oct 15, 2017
    44
    93223
    The neutral switch that is
  16. civteck
    civteck Respected
    Sep 6, 2017
    114
    NJ
    Easiest is to swap it, all or nothin..
    Sent from my boujea ass phone
  17. boofoo
    Oct 15, 2016
    2,243
    United States
    It's the A/T gear shift position switch. The neutral switch is for a clutch/manual transmission.
    Removing the switch is not necessary but you may need to access and unplug it.
  18. 91LXDriver
    Oct 15, 2017
    44
    93223
    I can do that, give me 5 minutes to remove the cover
  19. 91LXDriver
    Oct 15, 2017
    44
    93223
    Cover removed
  20. 91LXDriver
    Oct 15, 2017
    44
    93223
    Probably do this but need to troubleshoot first, don't want to throw $$$$ at it when it could be something else
Loading...
Share This Page
