91CRX SI/B20b MAP Cel Code Help
Discussion in '4th Generation Honda Civic (1988-1991)' started by existanzcivicb20, Nov 8, 2017.
  1. existanzcivicb20
    existanzcivicb20 New Member
    Apr 25, 2015
    16
    Chicago
    Car is CRX SI I swapped it with a B20B and car runs great until I go to full throttle I get a Code 3 MAP sensor code and then the car runs like crap. I have to turn the car off and restart it so it will run good again. The engine runs strong as long as I do not go to full throttle. Only upgrades I have on the engine is ITR headers, Skunk 2 Pro series Intake manifold and Throttle body, and 2.75" exhaust.
    Things I have checked:
    Timing is good ( checked with test light)
    Swapped out the MAP with 3 other brand newsensors
    TPS is good and calibrated (have tested 3 others I had laying around)
    I have 3 ECU's that I have tried. P28 chipped, 2 x P75 virgin
    Fuel Pressure 28psi at idle with the vacuum line connected to the FPR and 38psi disconnected
  2. civteck
    civteck Respected
    Sep 6, 2017
    108
    NJ
    How are you calibrating the tps? Any cel's?
    Sent from my boujea ass phone
  3. existanzcivicb20
    Apr 25, 2015
    16
    Chicago
    Volt meter. and no other cel codes besides MAP sensor code 3
  4. civteck
    civteck Respected
    Sep 6, 2017
    108
    NJ
    WOT or closed? What values are you setting it to?
  5. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,218
    United States
    Code 3 is an electrical fault in the MAP sensor circuit.
    Start by using a multimeter to measure voltage at each of the three map sensor pins in the connector.
    Post voltage readings by wire color in the connector.
  6. existanzcivicb20
    Apr 25, 2015
    16
    Chicago
    closed to WOT, .5v to 5v.
    Boofoo I have done this but cant remember the exact values. I will check it out after work and post the results.
  7. boofoo
    Oct 15, 2016
    2,218
    United States
    For the initial test, unplug the map sensor and then measure voltage at the connector pins with the key in the ON(II) position.
Share This Page
