Mikes92Civic
I have a 1992 Civic Vtec SOHC 1.6l with air that just started acting up a few days ago. On start-up the car runs fine opening at about 1100 RPM then settles down to about 800 after a couple minutes where it will stay until the car gets hot (about 15 minutes). Once hot the idle will reduce to just above stall at about 400 RPM. There is no fluctuation in the idle, acceleration is fine but the idle drops lower the hotter the car gets but bottoms out at about 400 RPM every time I come to a stop. The car shakes heavily when the RPM drops below 700 RPM and this problem is consistent, it happens each time I take the car out. The car has not come to a stall yet but it does get close but only when hot.
Any suggestions would be most welcome.
