What's up everybody?
Today I installed a new timing belt/water pump/tensioner pulley... Went pretty well once I got the 1/2 17mm socket. lol Anyways, the only issue I had was one of the water pump bolts sheered off, it was a 10mm bolt. Should I worry too much about this? I got a good seal with the gasket and a bit of Hondabond, and the pump didn't move whatsoever. Also, upon initial start up the belt seemed a bit wobbly on the rad side. I did the tension procedure to the book but only went 3 teeth. The car fired right up and eliminated the notorious "whine" that went along with the throttle, figured it was bearings in idler or pump so I replaced everything.
I guess my questions are, should I worry about the sheered bolt? And is it normal to have a slight wobble on rad side? Should I have went more than 3 teeth?
Sorry for the book, just want to make sure s**t is straight. Thanks in advance.
