So what i need help with is I have no clue on if this is hooked up right this is just how another tread on honda tech did it. My problem is that the boost gauge stays at zero and when i get on it it will go down into vacuum instead of up to psi. Any help would be much appreciated.
Ok i only used one plug off the wastegate because thats what i was told to do. The blue line runs to the manual boost controller.
Uploaded with ImageShack.us
Ok the blue line is coming from the wastegate and the black one leads to a block that the boost gauge hooks into then it go's the the brack booster.
The clear lines go's to the boost gauge.
