95 EX 1.6 5-spd Trouble Codes
Missy
Hooked it up to a scanner and got these codes.
15-1 Ignition Out Line or Circuit Failure
08-1 TDC Sensor No Signal
08-2 TDC Sensor Noise
Where do I go from here...
SeeOurWrecks
Have to say replace dizzy...what kind off symptoms are you having?
Tapatalk rocks!
Missy
Driving down interstate accelerating down the on ramp and it died... i put it in neutral while coasting and started it back up. put it in gear, accelerated, went about 100 - 200 ft and it died again. Put it in neutral started it up put it in gear and accelerated and was fine. then it was fine drove another two miles to my house. then abt two hrs later drove 10 miles and then it did it again on a side street.its been really hot here in Mid Tn.. figured it was the distributor. someone thought maybe fuel pressure but this rules that out I guess. My idle likes to dance ( having a power surge at the moment and paying attention to flickering lights) like yeah. i dont know how you would describe it. almost as if i was revving it but im not. only going between like 600 and 1200 rpms
