98 Civic losing power while driving
Discussion in '6th Generation Honda Civic (1996-2000)' started by lisitpc, Jun 19, 2017.
  1. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    98 Civic is losing power while driving. It is not stalling. The engine stays running. Pressing the accelerator has no effect. No lights come on the dashboard. Starting and restarting the engine it eventually catches, but it does not crank strongly and the engine kind of lurches. This happened while driving and also at a stop light. I just started and restarted the engine a few times and it cranked fine, so the problem is intermittent.
    Battery is good. I can hear the fuel pump humming when I start the engine. I thought it might be the main fuel pump relay but I replaced that to no avail. It's got new spark plug wires.
    It's very hot here and seems this issue started with the summer heat. (+98 degrees)
    I replaced the ignition switch a few years ago so I don't think it is that.
    I would appreciate any tips you have.
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,231
    United States
    What CEL codes are thrown?
  3. shuaib.jacobs
    shuaib.jacobs New Member
    Jun 19, 2017
    3
    London, United Kingdom
    What type of fuel are you using? How long since you last had fresh fuel in your tank?
    Sent from my LG-D851 using Tapatalk
  4. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    There is no yellow light to check, if I am understanding you correctly.
  5. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    The same gas I've always used. This is all on the same tank though.
  6. XpL0d3r
    XpL0d3r What Civic? Staff Member Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Mar 8, 2007
    8,894
    Rochester NY
    I would top off with fresh gas.
    Does the issue occur when the engine is cold, warm, or both?
    I would also check your grounds and clean them if they appear to be rusty or corroded.
  7. shuaib.jacobs
    Jun 19, 2017
    3
    I would 2nd that, definitely check the alternator and battery contacts, clean and apply battery contact grease. Let us know how you getting on.
  8. shuaib.jacobs
    Jun 19, 2017
    3
    Also measure values on alternator.
  9. boofoo
    Oct 15, 2016
    2,231
    United States
    Does the CEL work? Previous owners are notorious for disabling the the CEL.
  10. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    Both, but more so when the engine is hot.
    The grounds all look good.
  11. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    Yes it works. At least it was a month ago when I got an unrelated code. It has never been disabled.
  12. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    I'm going to have the alternator checked.
    I replaced the fuel filter. Didn't help.
    It's having startup problems now. Cranks but doesn't catch. Eventually it does after sputtering.
  13. boofoo
    Oct 15, 2016
    2,231
    United States
    Turn key from OFF to ON(II). Does CEL come on for 2 seconds and then turn off?
  14. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    Yes it does. Good idea.
    I just tried it, car was cranking but not starting.
    It's got a 5 year battery that's only a few months old. Cranks strong but didn't catch immediately like it should.
  15. boofoo
    Oct 15, 2016
    2,231
    United States
    Check the mechanical timing. The timing belt may have skipped some teeth.
  16. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    I will, thanks.
    What is odd is that after I replaced the fuel filter, I drove it for about 10 miles with no issues. A couple of hours later I went to drive it again and the problems are back. Could there be something on the gas tank that settled during that time and clogged the system?
  17. boofoo
    Oct 15, 2016
    2,231
    United States
    Does the engine start and run well with starting fluid?
    A clogged fuel filter will generally throw code P0171.
  18. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    I have not tried starter fluid. And it has not thrown any codes. I emptied the old filter but did not see any particles.
    If it starts well with starter fluid, what would that indicate?
  19. boofoo
    Oct 15, 2016
    2,231
    United States
    A fuel delivery problem.
    But also check the mechanical timing.
    Have you checked for bright spark at all 4 spark plugs?
  20. lisitpc
    lisitpc New Member
    May 20, 2013
    18
    Austin, TX
    No, replaced the wires though.
    Those plugs are NGK plugs and were replaced about 15000 miles ago so I was thinking they are still good.
Loading...
Share This Page
