98 EX: Sparks under car now cranks but won't start
gotcher17
Lastnight when I was on my way home my car broke down, I was only doing 55 in 5th. All I know is it will crank but wont fire, sparks came from under my car that sat and burned on the road, and when I popped the hood there was a burnt smell coming from the driver side. All the belts that I can see (3 of them) are still good. I need help figuring out what could be wrong with my car. Thank you for reading.
When you turn the key to ON(II), does the CEL remain on or does it turn off after 2 seconds?
io_303
NIFOC
Does it sound normal when you crank it? What kind of noises did it make when it died, or did it just shut off?
gotcher17
It cranks just like its going to start but it wont fire... There was a very faint "click" when it happend
1) Turn the key to ON(II). Do you hear the low humming sound of the fuel pump priming in the gas tank for 2 seconds?
2) Check for spark at the plugs -- click link in my signature.
Post the results of these tests.
io_303
NIFOC
can you see where the sparks are coming from?
gotcher17
yes, I can hear the humming and it is sparking good
Do you have spark at all four plugs? If so, check the mechanical timing to see whether the timing belt skipped a few teeth. The cam and crank should be perfectly synchronized at TDC1 as shown in the diagram below. This is checked by removing the valve cover and upper timing belt cover, turning the crank pulley COUNTERCLOCKWISE only until the cam pulley is positioned at TDC1. Then check whether the crank pulley is likewise at TDC1.
If the mechanical timing is fine, then compression test the cylinders.
All in all, the Civic is pretty reliable, but like any car, it must be properly maintained to realize the benefits of its reliable design.
