I figured it out...if anyone in the future need to ever change out the clutch from the compressor cuz some do come with clutches, I know the process (this is for a honda civic ex 2000). First off, the reason why im doing this is bc i didnt want to change out a perfectly good compressor when the only problem is the ac clutch pulley bearings. The price for a brand new compressor is around $325 and for a AC clutch kit, its only $80! Also, if I had bought a new compressor, I would have had to evacuate and recharge my AC system, which would have cost me a lot more. So the tools I rented from Autozone:
1) AC clutch Holder - this allows you to take of the retaining nut that hold the AC clutch. This part took me a while since I didnt have an impact gun. What you wanna do is take all 4 bolts that hold the compressor in place and let it hang off the two hoses. The reason for this is so you can get enough space.
2) AC clutch puller - this tool allows you to take off the AC clutch pulley, which is the part that the belt sits on that freely spins.
3) snap ring plyers - I bought this from autozone. Once you take off the AC clutch, theres a snap ring that holds the AC clutch pulley. Once you take off the snap ring, use the AC clutch puller to pull off the AC clutch pulley. After the AC clutch pulley is off there will be one more snap ring which holds the coil assebly. Take that off and install the new one. For me I had to use the two old snap rings that I took off the compressor, since the ac clutch kit that i bought that came with snap rings did not fit.
Hopefully this can help someone out for future issues...
If anyone needs further assistance on this i can help.
