Roelekhatch
I've been trying to figure out why my alternator is not charging my battery. Ie tried three different alternators that got tested and they all were tested good. Here's the things I've checked:
1. I've check the alt and vss fuse under the dash which is fuse 15
2. I've check the white wiring going into the under the hood and it had no resistant which means its good I'm guessing.
3. The alternator is getting the battery voltage. Which is 12.4-12.6 when te car is off.
4. When te car is on voltage goes 12.2 and gets lower and lower.
5. I also checked the ELD and it was fine.
6. Sanded all my grounds
7. When I disconnect the postive terminal at the battery while the car is running. It does instantly.
It's been such a long week trying to figure this thing out. Im starting to think its the alternator plug(green one with 4 wires). im pretty sure the blk and yellow wire is suppose to have voltage when the car is on(II) but its not. and fuse 15 is not blown. I'm open on trying to get this fixed if any clubcivic member could help would be very appreciated. Thanks
