B16 swap from d16y8
williammw20
Fixing to get started gathering parts I need for a b16 swap which trans would be best? Can I use the gsr trans?
5SpeedEJ6
Not trying to be 'one of those' but there are hundreds of links out there showing you basically step by step and/or what parts you need to pull this off. Short answer? Yes you can use a GSR tranny.
Literally took one search, 10 seconds:
http://hondaswap.com/threads/b16-into-civic-ek-help.44608/
http://www.clubcivic.com/forum/threads/how-to-swapping-a-jdm-b16a-gen2-obd1-motor-into-a-99-00-civic-ex.91064/
http://honda-tech.com/honda-civic-del-sol-1992-2000-1/b16-swap-ek-sedan-2809193/
http://honda-tech.com/honda-civic-del-sol-1992-2000-1/ek-b-swap-neccesities-parts-list-modification-2850213/
Esotericimage
Taking an H-T break
GSr is a bit longer geared.. but wouldnt the B16 trans be suited for the b16 engine? But if you have access to a GSR trans, grab it as they arent many available anymore
EDIT: I still dont know why people swap from a 1.6L to a 1.6L.. If your going to change engines, get the bigger one
