B16A to B20B questions
kuninspoon
I have some question/problem. Im using civic sr4 with b16a inside. And now i want to upgrade the block to b20b.
1 - can i use my old ARP stud in my b16a when i
install new b20b block? (Still use same head
from my old engine).
2 - which head gasket can in use. I mean the
thicknes of the gasket if i use block b20b 99.
3 - can i use standard conrod bearing,conrod
piston and piston for high rev or must change
this 3thing to performance/racing type?
4 - are b16a alternator,compressor air-cond and
power stering pump same as b20b so that i
just plug and play this thing when i install the
block?
5 - is there no need to modified the engine
mounting?
6 - which hicam is more better. The b16b typeR
or b18c typeR?
I can only help with #1... Yes you can likely reuse them -- they're ARP which are top quality. Just check the threads for stretching or damage before reinstalling.
