beastmodeeg
Hey yall, i had a quick question about my built on a b18b1. I changed out the main and rod bearing on my build and as i had it on my engine stand upside down, some of the assembly lube went thru my cylinder walls (pistons installed already) is that normal or could my piston rings be bad. I was running it on low oil pressure that's why i had to change out the bearings i had almost spun. Please help.
