B18b1 swap into 1998 Civic
pitbull80.cg
I just got 98 Civic 5 speed 4 door lx manual transmission and I am buying a gsr for the B18b1 to swap. Buying whole car. How much and what do I need to do the swap?
Sent from my SM-S120VL using Tapatalk
Want to do the B18b1 swap!
HeX
Authoritah, respected.
I moved your comments into your own thread as asking this in another thread constitutes as thread jacking. I also merged both comments since there's no need for them to be separate. Please familiarize yourself with the edit option.
Lastly, familiarize yourself with the search function. Every question regarding your engine swap has been covered, including general listings of the needed parts for any swap. Had you done so, you may not have needed to ask anything in the first place. Once you've done thorough research, ask any unanswered questions here. Good luck.
:welcome: to ClubCivic!
Good platform to work with.. same car I put a B18 into!
Hard to remember all of the parts off the top of my head, but as HeX mentioned, search around and you'll definitely find the answers as this is a pretty common swap.
B18 motor / tranny
B16 Rear T bracket
Integra shift linkage
The correct ECU (if you're buying the whole car, use ECU from donor car)
I think some IACV wiring?
Use Synchromesh for MTF
pitbull80.cg
It's a B18b1 but it's out and mine is standard. That's going to cost me More right?
