i have been bleeding my clutch for two days now. i have no back pressure on the pedal at all i have to pull the pedal back up and push back down. i have replaced the slave the master. This all started when i had to put in a new clutch. i put in a stage I Zoom in the 02 Civic EX. i have two people working this and we still get no pressure(that would at least be something. i am tring gravity bleed tonight(going on day three)
why do i have no pressure at all at the pedal?
I just did a swap into my car and had the same thing happen. I bled the clutch and problem solved. I didn't have a second person but I can be pretty crafty in figuring out that a broom stick is exactly the right length to fully depress the clutch and have the other end lightly tapped into the door edge (no panels)
Anyways, lets make sure you're doing this right:
1)top of brake fluid
2)attach snug fitting tube to clutch valve
3)fill container ith about two inches of brake fluid
4)submerge other end of tube that is connected to valve into container
5)Push in the clutch pedal to the floor
6)loosen valve nut
You should see a short burst of air bubbles in fluid thats in container.
7)once the bubbles stop, tighten the valve nut
8)release clutch pedal
Repeat steps 5-8 until no more bubbles appear (usually about 4-5 times
IMPORTANT: Watch your fluid level!!! If it gets too low you'll just put more air in the line.
