amnelson87
Hey everyone. Thanks for the feed back in advance. So i was driving my 1995 honda civic del sol vtec dohc and i noticed the temp gauge was pegged at the H. I only had a couple exits on the freeway left to get to where i was going so stupidly i kept going. Shortly after i heard a loud pop noise and the car began smoking. I pulled over on the side of the freeway and before i could shut down the engine it clunked a few times and then turned off on its own. i let it cool down for a while and tried to start it with no luck. I ended up getting it towed home. I looked into the engine and saw that a hose other than the upper or lower radiator hose was blown apart. I change that hose along with the upper and lower radiator hose. I also changed the thermostat. I filled it back up with coolant and it wouldn't start. I did take the radiator cap off and turn on the heater full blast. The coolant was shooting up like a fountain when i would crank with no cap on indicating the head gasket was blown. My question would be if the head gasket is the problem or if i could have blown the motor.
