bought a boosted car need some help.noob here
josh kaegael
i traded my lowered blazer for a clean 00 civic coupe.i know the kid that originally built the car but some dumbass had it since so now im here looking for some assistance..the car has low compression pistons bored and decked has bigger injectors.the car is only running on a basemap and has a jumpy idle.the car only runs about 6psi and thats fine for now but i want the thing to idle better..it jumps between 1000-1300.whats the cheapest way to tune it and some input on what i should do..the original owner of the car/builder of the car says i should run a smaller turbo and get it tuned,he put a 70 trim on it.please help thanks
lethal6
Your Mom's Moderator
Cheap and tune shouldn't be in the same sentence. A badly tuned turbo build will kill an engine in a hurry.
Base tune should be run, in my opinion, only a short period until a proper tune can be done. The tune is the single most important thing in a turbo build. It can be the difference between a reliable set up and a total money down the drain situation. Sadly it's one of the most cut corners in builds, especially from impatient newbs.
2slo4u
wait4me
^^x2
Get that tune as soon as you can. It'll most likely fix the idle and the car will run much better and hopefully longer.
josh kaegael
so how much am i looking to get a good reliable tune on this car
Depends on what management software is used and your local tuners rates. I'd say to be done right you'll spend $4-500.
mc360
boosted hx
The idle problem is most likely in the basemap tune, I have had two civics boosted that acted like the iacv was bad as soon as the basemap was ran, once tuned it went away. The most I have payed for a dyno tune so far was 250$, it seems now the tuners around here are switching from an hourly rate to a set rate at 250$ for N/A and 300$ for turbo cars.
Esotericimage
Taking an H-T break
Yea I heard the cost has gone up.. My tuner still gives me the old rate thank god.
