I know this has been discussed before but in my mind it is not a settled matter.
I'm talking about using your starter to break loose your crankshaft bolt .
My car is a 88 civic with a D15B2 engine. I have read people ask which way the bolt loosens and they go into the lefty loosy / righty tighty thing.
So... one of my first questions is, is it a left hand thread, meaning does it loosen counter clockwise?
Also I have read people say that my engine turns counter clock wise and others say that it turns clockwise. Well...that would depend on whether you are viewing at the front of the engine or at the back of the engine. ( like you would if you were standing in front of your car and saying that the passenger side was the right hand side.)
So, to make that clear if you pull off your left front tire to get at your crankshaft and are looking at your crankshaft, which way does the crankshaft turn , when running, clockwise or counter clockwise.
Now, still looking at the crankshaft which way does the crankshaft bolt loosen, clockwise or counter clockwise?
I have also seen where people say that you can use this method of breaking your crankshaft bolt loose with your starter and you can also use the same method to tighten it. This sounds impossible to me unless you can somehow tell your motor to turn backwards for your immediate pleasure.
And finally what do you think of using your starter to break loose the crank bolt. Can it damage your starter.
I dont think I can use the Honda special tool on my car to hold the crank from turning.
( ps Yes I realize that you have to disable the car from starting.)
