Clutch pedal's losing pressure
daytripper
ijuanasauras Rx User
My clutch has been losing pressure lately. When it does it wont start disengaging until about 2/3rds down and I have to bang it in gear. It also hangs downs in the travel. If I lift up on the clutch pedal with my foot, pressure comes back in a few seconds and it shifts fine. The pedal bracket isnt loose and I have the right amount of freeplay when the clutch is working. B16 with Y21 tranny.
defvayne
Set This World On Blaze!!
Slave cylinder is shot.
Kswest
Failboat sails at 9
yup. slave cylinder. I have had two go out on me, one on each of my hondas. Pretty cheap and easy repair. After you fix it, change your shifting/driving style just a little bit so you can conserve the life of it. I had a tendency to press the clutch the the floor and then some, just because of my long legs trying to stretch out. By doing so you stretch the cable and slowly create a leak in your slave that will eventually turn into said situation above. Hope that helps.
Check for a fluid leak from the master cylinder, especially from the area above the clutch pedal in the cabin. If a leak is found, replace the master cylinder.
31dev31
Chillin' Canadian Member
Bleed clutch hydraulic system, check slave, then master.
