regularcat
02 Honda Civic EX
First off, apologizes for the long post.
Yesterday we noticed that my coolant reservoir was low on coolant, had enough to fill it half way between min/max line.
Took it out for a drive and when i returned home i noticed the sound of pressurized air and seen spots of fluid under the hood.
Clearly the cooling system had some air still trapped in it, let it cool and removed the radiator cap to release the air, fluid is where it should be.
My issue is the fluid has a whitish tint to it, so after shi**ing my pants thinking head gasket immediately i proceeded to check my oil and trans fluid, they turned out to be fine, car runs well, no smoke out of the exhaust and the coolant doesn't have that oily feel nor does it smell like oil, smells, feels and tastes exactly as coolant should.
Not too sure what type of coolant was previously in the vehicle, i added some most likely mixing the types.
As of right now i am hoping it is not the head or inlet gasket or turbo seal leakage. (did tear the turbo down and back together again making sure everything was tight just to feel good about it, this was before the fluid addition)
Is it possible that the mixing of the fluids or the fact the car was sitting for a few days in weather ranging from cold to hot, moist and humid (i am in south carolina) be the reason the coolant looks like it does ?
