Kyle_83
Hi
I have a 2005 Honda civic SE Coupe 1.7 (280,000 km) with a new used lowish km engine installed almost a year ago. Im the original owner.
Anyways my Honda is burning coolant. I can smell it burning after a long drive. No leaks. I can drive about 140km distance on Hwy with no issues, but then when I get off the hwy the temp Gage will red line (red hot).
I turn the heater on or up full blast and it cools down and its fine. But sometimes the heater will turn from hot air to cold air and the temp will redline and not cool down unless I Rev up the engine to get the blowing cold air to turn back to hot air, then the temp Gage will cool down quickly and everything will be fine. Usually happens at red lights and once I start driving again and the heater kicks back to hot air then its all okay.
Then after driving that 140km, I will drive about another 25km on a 80km road trying to control the temp Gage from sky rocketing when I stop at red lights.
I will reach my destination, Coolant is not bubbling when I turn the car off and theres no white exhaust smoke. Then I will check the coolant levels and they will be low so after hours of cool down time ill have to fill up the reserve coolant tank and fill up the main coolant tank so I can drive back home.
I replaced the engine a year ago with a used engine with about 150,000km on it. I put in a new temp Gage, all new hoses, new radiator and water pump at that time. Also put in a new exhaust manifold.
I can drive around town locally with no problems, I dont need to refill the coolant every trip as it doesnt leak out. I would add coolant once a week or so when driving only locally.
I have no idea what the problem could be. My friend said the new used engine doesnt sound that great but this is the only problem I have. I only had a 3 month warrenty on this engine and had never went on a long drive so I never had a issue until after the warranty was up.
Any ideas what this problem could be and how I could fix it?
Thanks
Kyle
Thanks
Kyle
