massasshadows
this has been a problem for some time now.
my CEL came on and i ran a scan tool and it said P0335, so i changed the CKP sensor and it ran fine for a couple of days then the CEL came back on spitting out the same code. it keeps coming back now, i've reset my battery more than a couple of times, because it drives so crappy.
i took it to a mechanic and he said that because it was an after market sensor from Kregan (O'Reily) then it might be that it was just a crappy one, and i should get a certified honda sensor. any possibility in that?
also i was poking around and i tested the sensor wires and they seemed to be okay, but i wasn't able to get inside the distributor. i got the outer casing off but there was another casing in the way w/ a lil wheel type deal in the way and i didn't know how to remove it. as far as looks go, it was all very clean.
i checked all other wires as best i could to see if any were damaged and it all looked fine.
my electrical skills are limited so i'm not even sure if i'm checking all the right places.
